Old 01-08-2013, 04:28 PM   #14 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
I think those hub motors might need one BLDC motor controller per motor. If so, that could get expensive fast at $600/each. And that's for the matching Kelly which I probably wouldn't go with.
But they can do regen braking.
Where did you get 38hp from? It's listed as 7kw. Maybe 38hp is peak output.
