Thread: Radiator LED
Old 01-08-2013, 07:04 PM   #4 (permalink)
Sven7
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
I am not good at electrical, but my friend who is, is (I think) planning to just interrupt the wire going to the relay (for a different purpose). You could probably cut the wire coming off the fuse, extend it through a hole in the firewall, and put an LED in line. Of course he is putting in an on/off toggle switch, not a light.
If you get one of the larger (~10mm dia) lights with built in bezel you can drill a hole in a blank dash panel and it will look OEM. Loose LED's are kinda hard to mount.
