Old 01-09-2013, 03:01 AM   #38 (permalink)
AaronMartinSole
Your car looks ridiculous
The Fantastic Festiva - '90 Ford Festiva L
90 day: 43.16 mpg (US)
A Civic Duty - '96 Honda Civic LX
90 day: 34.9 mpg (US)
Ranger Danger - '96 Ford Ranger XL
90 day: 17.42 mpg (US)
If I were to buy a new catalytic converter, I think I'll probably buy from this website, unless someone has a better suggestion. http://www.maxautosupplies.com/Catal...onverters.html
Problem is, how do I know which one will fit my car? I want to get a direct-fit one that I can just bolt in that doesn't require any welding.
edit: It looks like I'm going to need to weld and a direct fit isn't going to work, judging by the cat and the awesome weld on it. But this site is awesome anyhow: http://www.showmetheparts.com/
This is an awesome troubleshooting/flowchart if you've failed smog: http://www.catcoglobal.com/assets/fi...ionsPoster.pdf
[x]Oxygen Sensor
[]ECT
[x]Thermostat
[]Fuel Injectors
[x]Sparkplugs/wires
[]Throttle Body Injector (TBI)
[]Throttle Position Sensors (TPS)
[]EVAP System
[]Mixture Control Solenoid
[]Idle Speed Control Motor
[]Manifold Absolute Pressure Sensor (MAP)
[]Air Charge Temperature Sensor (ACT)
[]Idle Air Control Valve (IAC)
[x]Exhaust Manifold(s)
[]Canister Purge Valve
[x]Vacuum Hoses
[]Ported Vacuum Switch (PVS)
Well I've got a lot to do.
