Did mercedes have two fuel pumps? VW Diesels only had one, the injection pump sucked diesel from the fuel tank and more modern ones have a recirculating valve in the housing that the fuel filter screws in to so the fuel stays warmer and it only draws new/cold fuel from the tank at the rate it burns it so the fuel injection pump doesn't have to work as hard.
