Originally Posted by jakobnev
Have you tested if idle is higher in gear as opposed to when in neutral?
Yea no change. I'm sure it has to do with a VSS or IAB if my Jeep has one. Something is reading the speed and keeping the idle up to make it smoother to change gears. I'd like to bypass that without changing my choke function.
