Old 01-09-2013, 06:30 PM   #80 (permalink)
Josh8loop
Definately a Modder!
Any updates on this project? I have an VW Jetta TDI alternator torn apart on my bench now and I'm trying to see what if any modifications I could make to it to increase efficiency. The Low forward voltage drop diodes were my first thought as I posted quite some time ago. Active rectification sounds very promising and could add quite a bit more efficiency. Time for me to go back out in the garage to see if there is any room for me to sandwich a thin but wide diameter magnet into my rotor between the claws to magnetically "bias" the rotor field coil which should reduce it's energy requirements.
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
