Old 01-09-2013, 08:02 PM   #37 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
It will, but it is dependent on boost pressures. At cruise speeds and low loads, my engine will barely break 4 PSI. Under full honk it was 22 PSI, before mods. I have enough cooling air flow for the worst condition, all the time.
What I propose to do is tie the louver control to coolant temp, and have a boost pressure override system that will open things up with a boost pressure servo, as needed. I will monitor pre- and post cooler temps.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
