Old 06-15-2008, 02:04 PM   #7 (permalink)
fshagan
I have had a Prius since Feb. 06. On 395, set the cruise control at 70 and you'll get about 45 MPG. Set it at 55, and you'll get over 50 mpg. Expect about 49 at 65 MPH.
On the display screen, you'll see one or two buttons in the lower corners. One screen shows a bar graph of your performance in 5 minute increments and a gauge of sorts showing your current MPG. That's the screen I use most of the time to provide the "bio feedback" that really helps in trying to get mileage.
For instance, there are plenty of times I max out the MPG scale traveling 37 MPH on level ground with just slight pressure on the accelerator. I have traveled over 5 miles in this mode. If you remove your foot entirely from the accelerator, the car will go into "regen" mode and it will slow slightly, just like a regular ICE car does. So a slight pressure on the gas pedal going down a slight grade is sometimes better than no pressure at all.
The other screen is a fancy animated graphic that shows if power is coming from the ICE or battery, or flowing from the electric motor to the battery. There is also a digital readout of the MPG you have at that point, but it isn't dampened, so you get "25, 26, 40, 23, 35, 42," readings ... very hard to keep it consistent and use it for feedback. I prefer the other screen now, although I do admit I liked the nice animation at first.
Electric only mode is under about 18 MPH ... a very slow start and you can get it past 20 MPH. If you jam on the gas pedal, both gas and electric motors come into play to give you much more acceleration than you get in most other small cars. "Pulse and glide" is a technique hypermilers do where they take advantage of the "cruise on electric at 37 MPH" trick I mentioned above. They quickly get up to 35 MPH and then, with just slight pressure on the pedal, coast along with some electric assist for miles.
All the other things are the same ... coasting (with slight pressure on the gas) will net better mileage than constantly accelerating.
