Old 01-10-2013, 12:34 AM   #163 (permalink)
Sean T.
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
Do you think I would be able to do something similar to this with a can of expanding foam from home depot? Just for the top grille... (the spear is not there anymore, but instead mesh, very similar to the echo's stock grille)
That was the best pic I had that showed the shape of the grille.
Did you just use regular aluminum foil as the liner for the foam?
