Originally Posted by FieroChris
I have been digging for several hours now.... looking for a schematic of where these big caps go....
I love adams and (something alaska) have been doing with the ring cap and the IGBT's
it looks soooo sweet...
question is:
do the caps go on the supply side of the motor controller?? this is the only reason a B+ goes to the motor controller ?? since the controller turns on and off the M- ??
does the third lug of the IGBT go to anything ??
how does the IGBT get wired up ??
B = battery -
C = motor - ??
A ????
I covered some of this in my Uprising thread, but i will do so here as well for informational purposes.
The cap goes on the supply side as close as possible.
The terminals on the IGBT are
A = Motor Negative (M-)
B = Battery Negative (B-)
C = Battery Positive / Motor Positive (B+/M+)
The most important factor of a motor controller capacitors is not the capacitance, but the ripple current ability. You must be able to control and withstand the current pulses or else you will destroy things.
-Adam
