Old 01-10-2013, 05:21 PM   #2 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Maybe I should research a wee bit before I ask questions here.
From Wikipedia:
Toyota Prius Plug-in Hybrid - Wikipedia, the free encyclopedia
The Prius Plug-in uses three different batteries, two to provide all-electric drive and a third battery engages when the first two are depleted, allowing the car to operate in hybrid mode, like a regular 50-mpg Prius. According to Toyota, when the vehicle starts, the plug-in operates in all-electric mode, drawing electrical power directly from the first battery pack. When its charge is depleted, it disconnects from the circuit and the second pack engages and supplies electrical energy to the motor. When the second pack is depleted again it disconnects from the circuit and the system defaults to conventional hybrid mode, using the main battery as the sole electrical power source. Pack one and pack two will not reengage in tandem with the main battery pack until the vehicle is plugged in and charged.
So it appears that no, the HSD system will not try to recharge the pack that was filled from the wall.
The Following User Says Thank You to mechman600 For This Useful Post:
Cobb (01-10-2013)
