Originally Posted by 2000neon
Yeah it's certainly not far off level, but when doing the larger image the rear wheel seems to be a bit lower. It's pretty darn close though.
Bless you sir and thank you. You are right, RAM trucks have a rake to them, the rear is a little higher than the front. Many guys in my shoes do a 2inch front drop and 4in rear drop... Even with the topper on, there's still a suspension rake. I will put this template to good use I hope when I test my foam shaping skills.
