Old 01-11-2013, 11:58 AM   #55 (permalink)
KamperBob
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Originally Posted by crashnzuk View Post
Hey all, I'm new here but have been reading what I can about pick-ups. Has anyone checked economy while towing a trailer, shell vs open bed? I am making a trip to Idaho from California next week and will be towing my open car trailer with my '91 Dodge W250 4x4 reg cab long bed diesel pick-up. The truck is stock height (tallish) with an older Warn brand winch/bumper combo up front that I have fitted with an air dam that hangs 12" below the bumper with the bottom edge about 13" off the ground (even with the front axle centerline).
On the way up I will have an AMC Eagle wagon on the trailer and on the way back I will have a '71 Dodge D100 2wd flatbed on it. I would think that having a shell on the back would direct the air over/around the trailered vehicle better vs an open bed, do you guys think this is a fair assessment?
I can borrow a shell from a friend that has the same truck as mine to make the trip. I ran this same combo (air dam and shell) in the spring to Idaho and back, but wasn't towing anything and had a couple tanks with my best MPG to date, so I think it has merit. Just wondering what your thoughts are about hooking an open car trailer up behind it with the vehicles mentioned.
Thoughts?
Travis..
Food for thought: I'd at least consider putting the wagon on the trailer backwards for leg 1 of the trip. It shouldn't take long to test load both ways. Take pix and compare with Phil's template. Whichever better stuffs the wake I tow that way. For the return leg since you said flat bed my guess is the truck should face forward. Regardless, fold mirrors as flat as possible, etc.
Safe travel!
Recreation Engineer
