Insurance can be an issue especially in Europe. I was lucky enough to have a broker friend who did a lot of leg work to get it sorted. The thing is its all precedent. Now that the company have covered me in one ev another is no problem.
Last weekend I jacked up the front of the car for a look see as I had a sneaky suspicion that I may have a clearance issue between the motor frame and steering rack. Sure enough unlike on the E36 where the rack is mounted on the side of the crossmember on the 5 series its on top! Bit of headscratching later I think I have a solution. I picked up a driveshaft for the automatic version on ebay which is shorter than the manual. This will let me more the gearbox / motor assembly rearward by about 3 inches allowing the motor to clear the steering rack. I'll need to shorten the shifter linkages but that's only a bit of welding. Plenty of clearance in the tunnel. I doubt even a 9" motor would fit without this modification and I want the power of the 13"
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
