Old 01-12-2013, 02:38 PM   #7 (permalink)
freebeard
You could still do a restrictor plate. You can test whether you'd like it by putting a block under the gas pedal.
A screen sandwiched between two gaskets is *supposed* to improve atomization. Something like the Jet-A-Vator will prevent reversion (backfiring through the carb). A phenolic plastic 1/4" thick will block heat and might prevent vapor locking.
Hope you're feeling better.
