Originally Posted by SVOboy
Looks good so far, think it'll stay on?
When my wife saw it she said, "Uh, is it going to stay that white?"
I only drove as far as the end of the driveway with the cardboard on it to see if it would hit the street if driving out front-first. It doesn't, barely. Mostly I back out so that shouldn't be a problem.
As for the coroplast holding up, I think I'll add some tabs to the dam by folding it and screw it in with the screws vertical, like this:
That will hopefully make it more resilient and the screws won't be as visible from the front of the car. The existing dam will back it up and ought to prevent if from unfolding and acting too much like a scoop funneling air down to the ground. I may have to add some thickness to the 'plast, maybe another layer glued on partially to help make it stand straight. I'll have to wait and see on that, I guess.
