Old 01-13-2013, 06:47 PM   #82 (permalink)
radioranger
radioranger
My conclusion is the oil does help and hurt at the same time, it probably helps with the start up wear and tear, valve guides, rings etc, and hurts a bit with the higher temps or tendency to ping on hills, so i guess if your not going under heavy loads it's a good thing, as far as FE seemed to help then just stayed the same, not enough testing yet, trucks running great now though, may try super synthetic oil next since i use it in the old outboard exclusively now, . My old street bike a Suzuki 380 two stroke ran a good ten mph more top end and sometimes was so smooth you couldnt feel it run, pretty impressive. In general I think anybody running a carbureted motor should definitely add the tcw 2 or better,
