Old 01-13-2013, 09:28 PM   #97 (permalink)
FieroChris
Thanks for the info.
I am working on the design, and will probably design my own IGBT driver board.
not sure if the Cap needs much cooling so I may only put the water cooling under the IGBT's this moves them up closer to the plane of the cap terminals and the copper plates dont need to be bent. also looking at PCB as conductors for this and have found that they dont design PCB's with very thick copper, so I will use plate stock.
Adam, What thickness copper plate did you use in your design ??
The Following User Says Thank You to FieroChris For This Useful Post:
z_power (01-14-2013)
