Old 01-13-2013, 10:16 PM   #70 (permalink)
KamperBob
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Plan
Originally Posted by 2000neon View Post
If you do have an aerocap in mind, this might be useful as well:
It's tough to see what is the truck, but that gives an idea for plan taper down the sides (if you can stand to lose a couple inches, although it doesn't seem to come in much more than the thickness of the bedsides). This is the newer generation of Ram, but as far as this goes, it will be pretty close to your truck.
FYI, the scale is off by a factor of 2. The symmetry plane should follow the center of the truck not opposite side. You'll see more aggressive taper then.
Recreation Engineer
