Old 01-14-2013, 04:01 PM   #9 (permalink)
Gealii
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
Originally Posted by razor02097 View Post
Would this mod benefit a vehicle that uses DFCO? Do you just use it down hills and such?
It would benefit a vehicle with DFCO because DFCO is not always in affect where the switch would be able to have DFCO at any point and then instead of being in gear causing more drag it can be put into neutral coasting further. For example my car being an '02 i cant get DFCO under 45mph.
Search "Pulse and Glide", I would use it whenever coasting for a good distance.
"The only real mistake is the one from which we learn nothing."
- Henry Ford
