Old 01-14-2013, 09:38 PM   #234 (permalink)
freebeard
Those A-pillars, and the low-res jaggies in the B-pillars look challenging. I can't remember if the finish contours are 100% inside the foam.
Maybe poke a curved welding rod through there for a fulcrum for your tool and to protect the crown of the contour?
Were you to do it again; do you think cutting from sheets that are 2" down to 1/2" for different areas would save hand finish work?
