I think the best RPM range in this engine is below 2000rpm (70km/h in 5th), as before I used to drive at 2500rpm (80km/h in 5th) and didnt show a great improvment in therms of millage.
This is an 1.2 L (1206 cc), bore 69.7 mm, stroke 79 mm, compression ratio 10.5:1, power 62 kW /84.4 PS @ 6000 rpm, torque 114 Nm @ 3800-4400 rpm (MY2008), running 95oct gas.
I'm still searching for the fuel injection map to post in here.
Keep it green!
