Old 01-15-2013, 01:29 PM   #216 (permalink)
RobertISaar
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
how does the scanguage calculate fuel economy?
two possible methods, one of which is significantly better than the other but requires more information.
method 1 is estimating fuel injected based on airflow readings from the MAF sensor and the target air/fuel ratio.
method 2 is calculating fuel injected based on injector pulsewidth, RPM, injector flowrate, number of injectors and injection scheme to create a fuel flowrate in gallons per hour.
guess which one is more accurate?
