Old 01-15-2013, 02:59 PM   #217 (permalink)
christofoo
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
Originally Posted by RobertISaar View Post
how does the scanguage calculate fuel economy?
two possible methods, one of which is significantly better than the other but requires more information.
method 1 is estimating fuel injected based on airflow readings from the MAF sensor and the target air/fuel ratio.
method 2 is calculating fuel injected based on injector pulsewidth, RPM, injector flowrate, number of injectors and injection scheme to create a fuel flowrate in gallons per hour.
guess which one is more accurate?
Scangauge uses MAF. MPGuino uses injector pulsewidth, and is more accurate generally, and significantly more accurate on lean-burn engines.
