Old 01-15-2013, 06:52 PM   #185 (permalink)
christofoo
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
I realize there is a lot of skepticism here directed toward DCD, however I think it's quite clear that it will improve FE if implemented properly, the principle has been demonstrated previously and you'd expect DCD - or any other valve-open-cylinder-deactivation - to reduce pumping losses almost certainly on first principles. How can I say that?
Try a 'thought experiment' directed at ICE loss mechanisms:
8 cylinder sports car, 60 mph on flat ground (setup for high throttle loss in stock configuration)
Case 1: 8 cylinders fire, closed loop
Case 2: 2 cylinders fire, closed loop (wide-band O2 sensor)
Clearly in both cases the mechanical friction losses and accessory losses are the same due to identical rpm.
But internal fluid dynamics are not identical. In both cases the air volume flow rate as measured in the manifold will be the identical, since the volumetric displacement is identical.
However, since in Case 2 there are 6 cylinders that are not contributing energy via combustion, the 2 cylinders that are contributing must exert at a higher power level per cylinder.
Therefore in Case 2 the density of air in the manifold must be higher than in Case 1 to maintain stoich AFR. Therefore in Case 2 the throttle must be more open than in Case 1.
How then will total fluid (pumping) loss be different between the two cases? In Case 2 there is higher intake mass flow, so it's conceivable for valve, intake and exhaust system losses to compensate for reduced throttle losses, however in practical terms throttle loss always dominates. I.e. if you run out of gas descending a mountain, at what throttle position will the engine braking be most powerful? The answer is always low-throttle, the lower the throttle the higher the air flow power loss, and the more powerful the engine brake.
Case 2 will always have have lower BSFC in practical petrol ICE's, and higher FE.
So this may be very likely to work for FE, but I think this invention almost certainly dies on emissions.
Somehow I hadn't noticed or forgotten about Old Tele Man's post http://ecomodder.com/forum/showthrea...tml#post326136 It seems the EPA has already ruled on this class of mod and it's considered tampering.
I've thought this through some more since my last post, and I think the EPA is correct and that this will apply to newer generation engines as well. Any type of valve-open-deactivation is necessarily going to suffer from quenching the cat with cold air and also the EGR will be contaminated with O2. So this is now dead in my book. (As a separate but related thought, I'd also considered spoofing the TPS to get DFCO with wide-open throttle as a simplification of P&G/EOC, but it suffers from the same emission problems as DCD (well, give or take the EGR issue).
Earlier Heihetech argued that DCD is similar to DFCO regarding cat temperature, but I think that is incorrect. DFCO produces a much smaller mass of exhaust air due to low throttle and so DFCO will require many more revolutions to quench the cat. This is aside from differing usage profiles.
So I expect DCD to be illegal in the US with no possibility of obtaining EPA approval...
... until proven otherwise. (If I'd thought this all through already I wouldn't have bumped the thread, sorry.)
