Old 01-15-2013, 10:07 PM   #37 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.42 mpg (US)
Originally Posted by JRMichler View Post
I ran some quick tests to find which gear was best to climb a local hill. This testing does not come close to meeting the standards in http://ecomodder.com/forum/showthrea...ery-11445.html, but I thought the results might be of interest.
I regularly climb a certain hill. The engine is always fully warmed up, and I normally drive it at 55 MPH in 4th gear. For the test, I also tried 3rd and 5th gears while eyeball averaging the Scangauge MAP and instantaneous MPG displays. The results:
Gear RPM MAP MPG OAT
3rd 3380 10.0 11.7 43 deg F
4th 2470 11.7 13.5 37
4th 2470 12.0 13.2 35
5th 1800 13.9 15.0 27 Unable to maintain speed.
I got another data point. This time I went up the hill in 4th gear, setting the throttle so as to bleed off the same amount speed as in the 5th gear test. Results:
4th 2470 10.7 15.1 32 deg F
I estimate the best efficiency RPM at about 2800. Fourth gear puts the engine closer to its best efficiency point than 5th gear, but at an inefficient MAP. It appears that those two effects cancel each other out at this power setting and speed.
