Old 01-16-2013, 11:30 AM   #189 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by serialk11r View Post
t vago, you're forgetting that in order to produce the same amount of power, the manifold pressure needs to be higher.
Originally Posted by t vago View Post
Since DCD only cuts out a cylinder once per firing cycle, intake manifold vacuum never gets a chance to significantly lower, which would otherwise lessen the amount of pumping work needed by the 4-banger. At best, there is no noticeable gain in fuel economy. In real-world conditions, the OBD-II engine computer would notice the misfires being induced by DCD, and would throw the engine into a less-efficient limp-in mode.
