Old 01-16-2013, 12:49 PM   #4 (permalink)
nbleak21
Adventurist!
CLaero - '97 Acura CL Premium
90 day: 34.59 mpg (US)
CR-v - '03 Honda CR-V EX
90 day: 26.52 mpg (US)
Razor gave you a lot of great advice, I just wanted to mention in addition to removing all of the plugs when doing the compression test, be sure to disable the EFI (pull the fuse) as a safety measure... It is also good practice to disconnect the ignition coil(s), as on some models, they can easily burn out.
'97 Acura CL 2.2L 5spd
'03 Honda CR-V 2.4L EX 4wd Auto
