You want to see fender skirts?
Fourtitude.com - Fender Skirts: Sometimes They Work, Other Times Not So Much...
How often can you turn out different part numbers? You can count me in for a set for the Beetle, but it would be best if I can save up for 30-60 days.
I would be proud to wear a set to the NW bug-Run in Woodburn in late May. I'd even put you URL or OR code in the rear quarter window just above them.
