Old 01-17-2013, 12:25 PM   #11 (permalink)
Daox
Optimal intake temperature differs from engine to engine. Only testing will tell you what the best temp will be. If I had to guess, most engines seem to like ~105-140F.
Since the O2 sensor mainly controls fueling, I highly doubt you'd get any leaning effect from messing with the IAT sensor (except in open loop mode which is not often at all).
The Following User Says Thank You to Daox For This Useful Post:
Jakins (01-21-2013)
