Old 01-17-2013, 10:04 PM   #248 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by christofoo View Post
Yep.
Now, how is DCD different from lean-burn, you ask?
DCD cuts fuel entirely out of one cylinder, for a given firing cycle of an engine. So you have 3 (or more) cylinders, all burning a set amount of fuel, producing a set amount of work, and consuming a set amount of pumping work. You also have one non-firing cylinder, not producing any work whatsoever, but also consuming a set amount of pumping work.
The firing cylinders aren't leaned out at all. DCD does not do that. It only cuts out fuel from one cylinder in a given firing cycle. This is exactly what heihetech described for his wonder device.
