Old 01-17-2013, 10:08 PM   #249 (permalink)
christofoo
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
Originally Posted by t vago View Post
Now, how is DCD different from lean-burn, you ask?
DCD cuts fuel entirely out of one cylinder, for a given firing cycle of an engine. So you have 3 (or more) cylinders, all burning a set amount of fuel, producing a set amount of work, and consuming a set amount of pumping work. You also have one non-firing cylinder, not producing any work whatsoever, but also consuming a set amount of pumping work.
The firing cylinders aren't leaned out at all. DCD does not do that. It only cuts out fuel from one cylinder in a given firing cycle. This is exactly what heihetech described for his wonder device.
This is all correct.
Now consider that when we go from 4 firing cylinders to 3, changing nothing else, the 3 are not consuming enough fuel to produce as much work as 4. Correct?
