Old 01-17-2013, 11:08 PM   #140 (permalink)
RatherDashing
So im having a lot of trouble finding a descent worth the price civic vx/cx transmission around my area.
Guy at shop said that i needed a new transmission.getting the transmission issue fixed is next on my list
I just need some help on how i should go about doing it.shoud i just get a new bearing.exedy clutch kit and just go ahead and drop it and replace the bearing and clutch and put it all back it.
Also should i replace the flywheel while im down there? Any other seals or bearings i shud replace in the process? Im guna really start saving to do this as soon as possible.
I also noticed very little coolant building up by the engine stamp and going to locate the source of that while i do sea foam treatment and oil change tommorrow.
I really dont see why i would need a new one.its shifts into all the gears without grinding.and has no popouts at all
