Old 01-18-2013, 12:08 AM   #255 (permalink)
christofoo
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
Originally Posted by t vago View Post
Alrighty, then. I've demonstated lean burn. Now, you demonstrate how DCD is supposed to work.
? Are you agreeing with me now? Do you disagree with the problem setup in #253? Does it require clarification?
(I thought I set it up the same way you setup your explanation of lean-burn, which, by the way, was excellent and I'm very glad for the time you put into it.)
