Originally Posted by z_power
Could you post screenshot of 'controller settings' area of rtdexplorer?
Couldn't get a screenshot, but "copy and paste" works well.
Here you go:
config
Kp=002 Ki=160
throttle_min_raw_counts=0419 throttle_max_raw_counts=0683
throttle_fault_raw_counts=0100
throttle_pos_gain=008 throttle_pwm_gain=000
current_ramp_rate=006
rtd_period=00100
pwm_filter=0
motor_os_threshold=0000 motor_os_ftime=1000
motor_os_dtime=10 pwm_deadzone=05
motor_speed_calc_amps=000
battery_amps_limit=000
precharge_time=000
Again, everything was running PERFECT the night before. I plugged her in and charged the batteries overnight (which I do after every time I drive her) and the next day these episodes started happening as soon as I pulled her out of the garage. And I shouldn't really call them "episodes" because they don't happen once in a while, they happen every time I press on the accelerator.
Thanks for your help!
Joel in Philly
