Originally Posted by MPaulHolmes
There's also a variable called FB, which stands for fault bits, that shows up somewhere on the screen. Normally it should be 0. Do you know what FB equals when it cuts out? That would tell us if the throttle, current sensor, or a few other errors were happening, causing this.
Paul,
I'm not seeing any "FB" or "Fault Bit" option or setting or command or anything.
I tried updating to the most recent software configuration and I was told I already have it.
Where should I look for this "FB"?
