Old 01-21-2013, 01:53 PM   #13 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by Jakins View Post
Well dang thanks for letting me know. So what is the temp if any that it will be harmfull to FE? I know people like to fool their IAT sensors to lean the car out. That why I was doing it
Fooling the IAT to "lean the car out" only works momentarily. As soon as the 02 sensor catches on it will adjust the mixture back to stoichiometric. The 02 sensor is king of the [sensor] castle.
Timing is a different story. Like Daox said, a hot IAT reading will retard timing, if anything. That's backwards to what you want. That being said, I have messed around with fooling the IAT on many vehicles without any tangible success. The only engines that seem to respond well are diesels.
Actual hot intake temp is the key for some engines. But there again, many engines do not respond to HAI.
