Old 01-21-2013, 03:11 PM   #107 (permalink)
64jeep
Originally Posted by FieroChris View Post
Thanks for the info.
Adam, What thickness copper plate did you use in your design ??
Chris,
In my so far not fully tested design, I looked at the capacitors to determine the thickness. The pad where the copper mounts to has a certain size, for the C4DE it's 10mm (0.394 in) in diameter. And the threaded post is 8mm (0.315 in). The conducting area is 0.0438 in^2 if you subtract out a hole the size of the post. The "bottle neck" is where the copper leaves the pad, so I wanted to make the cross-section there as much as the pad area. Since the diameter is 0.394 inch, the circumference is 1.237 inches, so you need a thickness of 0.035 inches to get the same cross section. I think I found some 0.040 stuff. And for those of you in the Phoenix area, I go to this place called Industrial Metal Supply that sells all their scraps by the lb. I don't think I spent more than $2 on mine.
