Old 01-21-2013, 11:14 PM   #7 (permalink)
Electroddy
Electroddy's Avatar
The turbo has an O-Ring into the intake manifold, and the turbine outlet has a clamp. It sounds as if someone tried to remove the turbo, and messed up the O-Ring. The black smoke is caused by loss of boost. It is coming out under the hood, due to a loose clamp or blown gasket on the turbine side.
HTH Bart
The Following User Says Thank You to Electroddy For This Useful Post:
War_Wagon (01-22-2013)
