Originally Posted by bennelson
Which makes me wonder - if the truck is in Hybrid Mode, should the DC/DC converter be running or not? I guess if the engine is killed, then it SHOULD be on. On the other hand, if I'll be turning the engine back on soon, why bother? The battery will just start charging from the alternator next time the engine starts. I guess the only thing I wouldn't want to do is have the alternator and DC/DC converter BOTH running. They might not like each other that much.
If you had two large power diodes that were rated high enough then you could isolate the dc/dc converter from the alternator and whatever one was putting out a higher voltage would charge the battery,
that seems like the simplest solution if you want an alternator, is there a problem with not having an alternator and just running all of the electrical loads off of the drive pack? still having a battery that the DC/DC converter kept charged, for starting the diesel engine, but once the engine started the drive pack would recharge that starting battery.
