Old 01-22-2013, 02:41 PM   #12 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
See if you can remove the air filter housing and run it. I pretty much guarantee it is a cracked/broken exhaust bellows/pipe. However, black smoke will not happen with a boost leak unless the engine is under load, so if it is smoking black at idle, there is something more seriously wrong with it than a simple leak.
