Old 01-23-2013, 01:00 PM   #3 (permalink)
RobertISaar
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
Originally Posted by razor02097 View Post
There is a FPR on the vehicle that raises and lowers the pressure but I don't know if that will affect the calculation a lot or not?
the purpose of the fuel pressure regulator is to keep consistent the pressure differential at any vacuum.
ex: injectors firing at WOT will be 35PSI of guage fuel pressure with 0PSI of guage manifold pressure. injectors firing at max vacuum will be ~20.3PSI with negative ~14.7PSI manifold pressure.
it's actually easier to think about in absolute pressures, but that's how it works to keeps injector flowrate consistent across all vacuum levels.
if you had a rising-rate FPR, that's a different situation, but those are worthless hack methods of tuning fuel delivery.
