Old 01-23-2013, 03:42 PM   #23 (permalink)
busypaws
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
Has anyone played with coolant temp when the thermostate starts to open vs. where you turn on your cabin cooling fan. I try to wait till 140F before I start "extracting" heat into the cabin. It takes quite a long time for the engine temp to go from 160 to 170F probably because the thermostate is starting to open. So I run the cabin fan on high after it gets above 140 when it is really cold. If it is not too uncomfortable I wait till 170 since it is "free" at that point since the engine is already sending coolant through the radiator.
