Old 01-23-2013, 04:11 PM   #57 (permalink)
busypaws
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
I installed 3 - 100Watt heaters, One on oil pan, one on transmission pan, one on a flat spot I found on the engine. Right now I plug them in when I get up so they only run 1/2 hour before I actually leave. I've noticed about a 10F difference in temp between air intake temp and coolant temp (Scan Guage) at startup. Before I ran the heaters the two temperatures were almost always the same. So 300watts at 1/2 hour gives you a 10degree rise. I have a timmer so I could set it to run for an hour or more but have not done that yet. Just my experience.
The Following User Says Thank You to busypaws For This Useful Post:
paulgato (03-11-2014)
