Thread: new truck
Old 01-23-2013, 10:39 PM   #14 (permalink)
c_silva88
o - '84 Ford F150
Originally Posted by elhigh View Post
Is that the 300-cube straight six? That's a great motor, but if you have a household rule like, "No new trucks until the old one's broken," you might be stuck with it.
Start a vehicle page in the garage listing?
thats usually how it goes my girlfriend thinks im crazy never buying a truck or car thats newer then 95 and cost more then $1000. i don't like payments and i like the simplicity of the older trucks.
and for an update well the past few days ive been tinkering on the truck. i replaced the fuel filter and o2 sensor oil change and started putting the front end together.i also put a volt, oil pressure, and temp gauge set in to keep an eye on the truck vitals. on my to do list as of now is:
1. patch the floor
2.replace the computer controlled carb and tfi distributor with a normal carb and dura spark ignition.
3.full belly pan
4. lower it
5.put a radio in
6. convert the truck to manual steering
7.swap in a 5 speed and aluminum drive shaft
8.build a tonneau cover
9.remove any unnecessary weight
10.replace all fluids with synthetic
11.build a custom intake
12.upgrade all the power cables and grounds to 2 gauge wire
13.all new vacuum lines
14.replace all the brake and fuel lines with stainless steel lines
and lastly every one love pics
ID:	12321   Click image for larger version
ID:	12322   Click image for larger version
