You would be well-served by using a heat exchanger to heat your veg-oil blends. A dual tank is really the only way to make vegetable oil fuel work for the long term as cold starts and incomplete combustion creates accumulations of polymers in your rings and sump oil.
I'm not coasting, I'm shifting slowly.
