Originally Posted by ChazInMT
Yes, you could do it this way.
But I'm 99.5% sure it is an incorrect application.
I didn't just guess on the other one. Others told me that was the correct application.
Not suggesting you guessed,
But until I understand more, the format above using vehicle centreline seems to be more appropriate, hope Aerohead can jump in at some point and clarify this.
Most of the reading I have done has been here and hence is second & third hand information, others have read the actual text books and I rely on them for guidance.
Edit:
For those in the know, I can't get the degrees symbol up, tried the 0176 and doesn't seem to work for me.
Just realised Aerohead just posted will read his response now.
