Originally Posted by aerohead
The 'Template' is rough although with a number of major bulkhead stations established,a 20' length of 1" scedule-40 PVC pipe is all that's needed to produce a near-flawless contour.Sure it's low-tech but it will get you in the winner's circle.
Got all the other stuff, and yes template is a bit rough, but using the right materials as above allows nature to smooth out the inconsistancies.
I suppose my primary query at this point is how to apply the template with regard to top and side views, the 5:1 is the ideal, but on what dimensions should one apply it to, the width or the height or both?
