Originally Posted by Old Mechanic
What is the all electric range of a first generation Insight? You are missing the point, which is the storage and release capacity of hydraulics allows for highest efficiency operation of an IC engine or a battery powered car that does not need voltage control for speed control.
Nope, not missing the point - which is how much an hydraulic energy storage system would need to weigh to store the same amount of energy as the Insight's battery.
The gas in an accumulator is an inert gas, same type used in some types of fire extinguishing systems.
Irrelevant, because what causes the damage is the sudden release of pressure as the storage tank ruptures and sends shrapnel flying in all directions, not chemical reactions.
Accumulator technology is ancient, dating even before WW2. How many times have you heard of an accumulator "explosion" in any application that ever cost a single human life.
And I would bet that all those accumulators are a) very strong and heavy; and b) at comparatively low pressure. To be of practical use in a passenger vehicle, they need to be light and work at very high pressures.
while I don't remember a single instance of a death related to hydraulic accumulator failure.
Any accumulator in an airplane would have to be pretty small (about the only practical use I can think of is landing gear, and perhaps hydraulic controls).
Maybe james can provide us with some examples?
Now how am I supposed to do that, when this type of accumulator basically doesn't exist yet? But if you do a search, you'll find lots of product literature (all pdf, so I can't quote it) with warnings about how improper use can cause serious injury or death.
