Originally Posted by MTXA
I have it way too easy. Toyota has a machined port in the rear of the engine block for the heater. All I have to do is remove the airbox, move the clutch bracket, coat the heater with thermal grease, shove the heater into the port until it clicks, reinstall the removed parts and route the AC cord. I'm estimating under an hour or less and the cooling system never needs to be opened.
I am a fellow xa driver. Did you get the block heater from the dealer? What did it cost?
I also have a short commute at 2.5 miles each way. I have an 80% grill block mobil1 synthetic oil and try to time lights. It has been in the 20s here so the commute has been brutal currently 23 mpg or so in the xa.
